HKS Camp wiring...
Turboed240
I am trying to get the schematic for wiring the HKS camp system on an s13 w/sr swap? Can anyone help me out with this? I would appreciate it.
TeamSLideWays
Car: drifting
o0oo0o you got one of those buggers ehhh!! lol...well i dont know about it but let me know on how you like it. was interested on one of those...thanks,B
HotWIRED
HKS CAMP wiring codes;
Main unit:
Yellow- 12 Volt constant (battery)Red- 12 volt ignitionBlack- Gorund (EARTH)Blue- Speed sensorBrown- RPMGreen- Injector pulse (#1 injector)
HKS ECU lettering codes:
B- 12 Volt IgnitionU- 12 Volt BatteryE- Ground (EARTH)P- Pressure sensor, Air flow sensorI- RPMS- Speed sensorT- Throttle position#- Injector signal
KA ECU wiring;
Y/R- RPM (pin 3)Y/G- Speed sensor (pin 26)W/B- Injector #1 (pin 102)
HotWIRED
I don't have the S13 ECU but I do have some the ECU pinouts for it though;
S13 ECU;Y/R- RPM (pin 3)Y/G- Speed sensor (pin 32)O- Ignition (pin 47)Color??- Injector #1 (pin 101)
Hopes this helps
Turboed240
The camp is gonna work out REAL nice. I didnt really wanna do alot of external gauges...with the camp, i can just use my monitor to keep an eye on my boost, egt, manifold pressure, etc. The only external gauge I will have is voltage and air/fuel. Def good purchase. Very Skyline-esc.
turboex
Hey man i am installing mine also. Did you ever figure out what color wire to hook it to for the injector? thanks
