Afrikaaner »
https://forums.nicoclub.com/afrikaaner-u143971.html
Mon Apr 26, 2010 8:02 pm
So i've had this sound since i replaced my flywheel, clutch, transmission, headers, and cats (all at once). I have no idea if this is normal, but it always worried me slightly, and now that my passenger side cat gutted itself, i'm more concerned.
first a little backstory: when i got the car, there was a burnt coilpack on the passenger-side cylinder closest to the firewall (cylinder 5 i believe). Took me a while to get it fixed, so i put some (not too many) miles on my car while running on 5 cylinders. i was concerned i may have damaged the cylinder/piston or something by doing that, but once i got it working, it seemed to run fine except for a very occasional bout of misses (never more than 1 or 2 seconds with misses) on (im assuming) the same cylinder which hasn't happened in many months now.
fast forward to this winter, i put on all the goodies i mentioned above, and it started making this hissing/grinding noise whenever the engine is under load (almost like a turbo spooling), and now the passenger side cat broke, and i'm wondering if it was due to something related to all this.
and now that the cat is a straightpipe, it seems that the noise isn't a constant hiss/grind/scrape like i thought before, it sounds like it might be coming from one cylinder as in its not constant, it seems to be the same noise repeated very quickly so it sounded like one. today i was driving it trying figure it out, and there seems to be a sudden change in the sound a little above 2000rpm, but that quickly returns to the same sound by 2500rpm, if not sooner. this may be my paranoia, but im starting to get concerned. any ideas about this? i'd really like to at least isolate the noise before i ruin another cat for the same reason. thanks!
