high output alternator
nosduj
Car: 90 300zx
Has anyone installed one in their z? if so where did you get if from? Ive been looking for one for a while and havent found one for under 400 bucks yet, which is rediculous. Thanks for any input.
Zak427
Car: 93 2+2 Twin Turbo
where did you find one at all?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
um.... if you need a high output alternator how many lbs of stereo equipment do you have slowing your car down?
Wetmyson
Car: Z32
evildky wrote:um.... if you need a high output alternator how many lbs of stereo equipment do you have slowing your car down?
phanatikz32
Car: 1991 NA to TT z32 biatch!
LOL LOL
i cant think of any other reason you would need a high power alternator other then to power an unneccesary amount of under car neons, hydrolics, and stereo equipment!
nosduj
Car: 90 300zx
No, I dont have an excessive amount of neons, hydrolics, etc. however, my pos stock 80amp alternator died, and I dont want to put another 80 amp one on there because it isnt even enough to keep up with the normal everyday loads put on the electrical system (ie headlights, stereo). Yes I do have an amp but it is for my mids and highs and only draws 30a at most.
evildky
06 Nissan 350Z GT
my stock alt powers my car fine,a nd I do have a little sub, if your getting bas drain might want to add a stiffening cap
mahchu07
Car: 1993 300ZX NA
Depending on your model, nopi online store sells a 90 Amp but its for the turbo model.
Zak427
mahchu07 wrote:Depending on your model, nopi online store sells a 90 Amp but its for the turbo model.
the turbo model will work on the na. plus it's cheap...dunno why
mahchu07
Car: 1993 300ZX NA
I figured as much, also figured someone would confirm after I posted that.
Dru Dru
Car: 92 300zx
http://www.motorcityreman.com/nissan.html
140$+160$
what do you guys think??
cause my battery, ABS, tail light, E brake lights all came on and wont go away like they normally do. so im guessing my car is gona run out of energy soon. also is a alternator replacement hard to do? i would love to do it myself and save a **** load of money but i dont want 2 **** **** up.
evildky
06 Nissan 350Z GT
alternator replacment is a PITA, just becasue it's hard to get to
but I wouldn't replace it unless it quits working, sounds you you are throwing parts at an undiagnosed problem
skinZ32
Car: 1992 300zx 2+2
almost the same thread from a couple of days ago
Dru Dru
Car: 92 300zx
yeah after i posted this thread earlier and went 2 go play some ball, as me and my co-worker were leaving my car wouldnt start and it WAS the alternator. lights didnt want 2 work, after my other friend gave me a jump my car wanted 2 die. i made it about 4-5 blocks with another jump along the way before i just called for a tow.
and my diagnosis was my stock battery was crappy so i changed 2 a yellow top, and the battery light would still come on at times so since its not the battery it had 2 have been the alt (which is was).
so now the stock replacement alt has 80 amps for 140$ and the high output has 160 amps for 300$. what do you guys think?
and how much am i looking at in LABOR costs.
evildky
06 Nissan 350Z GT
I have no idea on labor, I'd suspect about 1 hour, shop rated will vary, any where for $80-120 hr
the extra amperage only helps if you have more than 80 amps of constant draw, chances are you don't, most high powered amps are 50 amps and thats a peak draw not a constant
Dru Dru
Car: 92 300zx
do i have 2 get a alt that was specifically made 4 the 300zx or are all alts universal?? im taking it 2 a shop in a few hours.
300ZXbyCP
Car: '92 300ZX
'could just have a loose belt, or loose connection to battery, or any number of intermit. problems. alternators usually either work or not. a quick test would be to start and run the engine, then carefully disconnect the negative (ground) post at the battery. if the engine dies, the alternator is not working.
Always use the parts - factory or aftermarket - specific to your car, there are no universal parts (besides air fresheners).
skinZ32
Car: 1992 300zx 2+2
are you sure it isnt your amp drawing to much power. maybe try installing a capacitor (1 fared is good to 1000 amps). or the amp isnt still on when you turn off the car?
NolimitZ32
Check ALL of your connections between the ALT, BAT and Starter, I had a similar thing going on until i replaced the battery terminals (way cheaper then a new battery or alternator) Our cars are plauged with crappy connections in wiring so check all that first.
CRAZFNZ
Car: 1991 300zx TT
1985 300zx Turbo
Does anyone does know of a direct fit alternator with 100 Amp output or higher for a Z32? I have heard of I30's alternator will fit but the mounts are not the same
Reason: Merged with existing thread
NolimitZ32
CRAZFNZ
Car: 1991 300zx TT
1985 300zx Turbo
Thanks no limit I feel retarded...
NolimitZ32
Rubyz32
Car: 90 n/a z32
No mods as of yet
Should have gotten a red top. The yellow top is for extended drain. Like a boat or motor home.
THEdonSIMMER
Car: 1991 Nissan 300zx 2+2 VG30DE
2001 Chevy s-10 Crew Cab LS
I know where I work the labor time to do a alternator on a z32 is 1.3 hrs at $90 per hr. and its not to hard to do on your own if you have a few tools and a jack and jack stands.
NolimitZ32
Rubyz32 wrote:Should have gotten a red top. The yellow top is for extended drain. Like a boat or motor home.
No, blue top is a deep cycle for "extended drain" like a boat or RV, red top is starting only, and yellow top is starting and deep cycle and is exactly what you want in a car that is actually driven but has a large constant drain due to lighting or a sound system. Now my 2c: Optimas are complete and utter trash, they were great once upon a time but siince moving their ops to Mexico, their quality has suffered severely and failure rate has gone through the roof. AGM and Odyssey are the way to go but they are not cheap.
94TT
HEY IF YOU NEED A HIGH OUTPUT ALTERNATOR LET ME KNOW. I HAVE A BRAND NEW ONE THAT PUTS OUT MORE THAN 120 AMPS. FITS 90-96'S.
