Postby
midnightsliding »
https://forums.nicoclub.com/midnightsliding-u8138.htmlThu Oct 30, 2003 1:50 pm
witch injectors should i use, i want to run like 12 to 14 PSI on my KA, and i was wondering the difference between High and Low RESISTANCE injectors? but what size sholud i go with and a cheap place to buy them?thanks
Postby
nikn »
https://forums.nicoclub.com/nikn-u10833.htmlThu Oct 30, 2003 1:50 pm
which engine do u have? E or DE ... i think it makes a difference [not sure]. u will need top feed or side feed depending on that.. but u might have figured that out already
Postby
Nismo_Freak »
https://forums.nicoclub.com/nismo-freak-u248.htmlThu Oct 30, 2003 1:50 pm
midnightsliding wrote:witch injectors should i use, i want to run like 12 to 14 PSI on my KA, and i was wondering the difference between High and Low RESISTANCE injectors? but what size sholud i go with and a cheap place to buy them?thanks
Just that... the impeadance on the injectors is different for the signals. You'll just have to rig up some injector resistors.
Postby
Nismo_Freak »
You run it in the signal wires to change the voltage sent to the injectors. I don't suggest doing it yourself unless you know how "large" of a resistor to put inline.
