There seems to be a difference of opinion here.
I mean no offense in correcting anyone. If I am wrong, please correct me.
Read the following quote please
Quote »Light is reflection. We see "white light" because Red, Green, Blue reflect at the same time. We see black because none of the 3 color are reflected. If it is REAL 12000k, it will be so dim comparable to oem or even ebay bulbs. The least amount of photography or physics will tell you that color temperature does not dictate brightness, all it is is a measurement of color in light(s) At around 5500k is what human eye call "white" or "bright light". Which is why the 2 standard D50 and D65 (USA use D50, 5000k... europe use D65, 6500k) exist.
Now imagine you take red away, take green away since 12000k is all the way up in the color temp spectrem... does that sound like you're getting only 1/3 of the light? I am sure it is not exactly 1/3 of the light but one thing is for sure... you're getting less reflected light as supposed to all 3 color. Why is it that we can see lighting strike which is rated at 30,000k or stars rated at 100,000+ k? because of intensity is greater. Unless the power to the hid bulbs increase, there is no way a 12,000k bulbs will defeat 5,500k bulbs in terms of "brightness" at the same "intensity"
I ran ebay h4 housing before, they were not too good since the beams go all over the place. Now I run offroad Hella ones that are not dot approved. MY setup? lexus is300 ballasts (denso) and phillips 4200k bulbs with h4 adapter
your best bet is not to buy a hid kit. You can get OEM quality stuff at a cheaper price, expect to spend around 200~250$
phillips hid bulbs are 50$ a pair on ebay, hid ballast made by denso, hella, osram, keioto can be had for about 150$ a pair on ebay. Buy an adapter ring or get a rebased bulbs and you're done.
[/quote]Look at this chart:
this link will explain color temp further and has a good chart too:
http://en.wikipedia.org/wiki/Color_temperature
