Yes $300 is way too much that guy must be smokinn CrAcK!Mr. LS wrote:damn crazy how much peeps are charging for kits, I deal with kits, and I sell em for $125, you guys are nuts if you pay $300 for a kit!
Every kit is the same to install. I took the front bumper off to give myself more room to work with then i pulled the head light off then carefully swapped the bulbs plugged everything in then did a 10 min burn in and thats it.tyler_ofspain wrote:Those look nice... how were they to install?
well apparently they aren't the same because it wasn't hard at all for me and i didn't remove the bumper or pull the headlight off... i just wore latex gloves as to not touch the bulbsCodeRed wrote:Every kit is the same to install. I took the front bumper off to give myself more room to work with then i pulled the head light off then carefully swapped the bulbs plugged everything in then did a 10 min burn in and thats it.
$125 is more in my budget range. $300 isn't worth it.Mr. LS wrote:damn crazy how much peeps are charging for kits, I deal with kits, and I sell em for $125, you guys are nuts if you pay $300 for a kit!
