Hi, new guy here with a question
A home for 1983–1989 300ZX owners!
Crimsin
Car: 1978 280Z
I was looking at the Tokico shock and spring set on E bay, has anyone used this set?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
they are decent, I have the tokiko set on ,y Z31, huge improvement over stock, btu a logn way form coil overs
ravera
Car: 1971 Datsun 240Z
they run alright, nothing special. Cant really handle that much spring travel. If you just want tighter handling for a DD it's fine. But a solid set of Coilovers with Koni's or Bilsteins will be a HUGE difference.
Crimsin
Car: 1978 280Z
What about KYB, are they any good?
evildky
06 Nissan 350Z GT
KYB AGX are good, KYB GR2' are stock replacment as in if you got busted shocks and just want some non busted shocks they are fine, but if you are at all interested in performance they suck
Crimsin
Car: 1978 280Z
I couldnt find Bilsteins that would fit my car. I did a search, but turned up zero
evildky
06 Nissan 350Z GT
those of us runnign coilovers section out strut housings alllowing us to run different insertshttp://forums.nicoclub.com/zerothread?id=237090and here is a lengthy discussion about which inserts to use, koni, tokiko, carerra, bilstein, adshttp://forums.hybridz.org/showthread.php?t=138601
Crimsin
Car: 1978 280Z
I looked up more info on strut sectioning, b ut all I came up with was your, "strut sectioning 101". Do you have to section your struts? im not going to be racing it, just weekend crusing. Oh and thanks for not flaming me. I do know how to work on cars, it just seems that the Z in kinda needy
evildky
06 Nissan 350Z GT
I'm here to help wiht what I've learned along the way, mostly form mistakes
no you don't have to section your struts, it's only needed of you want to go wiht coil overs, if your car is a daily driver or weekend cruiser just call msa and get their springs and tokiko inserts, it's fairly inexpensive, it's a direct bolt in, it'll perform better thna the 40 year old dampers and wiht the lowering springs you won't hae to use aspring compressor to put it back together
Crimsin
Car: 1978 280Z
So, I guess Im going to have to find someone who will section my struts. I planned on going with modern motorsports coilovers
evildky
06 Nissan 350Z GT
beta motorsports and arizona z car both sell assymbled coil overs
Return to “300ZX (Z31) Forum”
