fastboatman29212 »
https://forums.nicoclub.com/fastboatman29212-u165024.html
Mon Jan 03, 2011 3:32 pm
We need more info. Does it happen at all speeds? Inclines and down hills too? What style carb are you using? Stock carbs heavily rely on vacuum lines, and if they leak (old and cracked) then that might be a possible source of the problem.
For starters, I'd put a bottle of carb cleaner in half a tank of gas and run it until she's about empty to see if that helps clean out something in the carb.
Give us a bit more info if you can. Let us know what you've tried already.
