help with wiring!!!
weems84
Car: Versa SL
I was attempting to install a back up camera and shorted the reverse lights out. I know all i need to replace is the fuse or the relay for the lights but cannot find it.
In front of the battery it has a fuse relay holder and says the relay is there but no relay for the lights only the horn.
I went to courtesy nissan and checked there diagram but does not seem accurate.
Anyone knows where the fuse/relay for the reverse light is PLEASE let me know.
Onyxblue
Car: 1990 300zx n/a, 08 Versa SL, 07 Pathfinder SE, 08 Sentra
You have another fuse box inside just above the mirror setting and dimming light combo switch. Open it and inside the cover you'll find out a diagram of the fuses.
weems84
Car: Versa SL
Thanks for that reply but i checked that one as well and it was not in their. I actually checked that one first before i went in the engine compartment.
I did manage to find it my self.
To the right of the battery underneath the intake piping their is a black and white box held on with 4 clips. Having a CAI i had to partially disassemble the intake to access the box.(stock intake---don't know if you can even see it) Once you got the box lose the fuses are all facing downward so you have t carefully turn it facing upward without yanking all the wires out. I think i saw about 15-20 fuses in that box.
Found it replaced the burnt fuse. Backup camera works great, turns on whenever i put the car in reverse.
kcourtad
Car: 2007 Nissan Versa SL Sedan
Pics ???
