NeedCAforS13 »
https://forums.nicoclub.com/needcafors13-u4234.html
Mon Aug 01, 2005 3:31 pm
Hey C,
You really don't need use the factoy boost controller and I actually don't recommend running the factory boost control soleniod. Its pretty useless unless you have everything else hooked up, and doesn't really do much even when it works properly. Just running a vaccum/boost source to the wastegate will work perfectly, and deliver stock boost quickly accomplish the same thing. Just run a vaccum hose from the port on the side of the intake manifold (between the #1 and #2 runners) to the wastegate directly. When you do get a boost controller, cut into this line, and run the controller in between the manifold and the wastegate!
Sean
