Beancooker »
https://forums.nicoclub.com/beancooker-u42602.html
Tue Mar 06, 2007 2:46 pm
Suspension may help. It will keep most of the movement from occuring. Don't use spring helpers or any kind of lifts, because with 20's it sits too high already. The adjustable struts will help, only if you keep them at their stiffest setting. I think that most of your problem is that your springs and struts are probably pretty worn out.
