xtwoonamatchx »
https://forums.nicoclub.com/xtwoonamatchx-u73446.html
Mon Apr 21, 2008 7:30 pm
for the ones on the door.... just kinda pry them off... gently on the silver trim around the handles cause they have 2 really fragle clips on the top and bottom... 3 clips total, work your way around from top, back, bottom... for the window switches. just put a flathead in between the "leather" and the panel and pry up, work your way around, and it should come up, unplug the harness and your good. just remember, that if you unplug that harness you'll have to reset the auto-up by rolling it all the way up, and holding the switch in the autoup position for like 10 secs... dunno about the others though, what are you planning to do?
