Hey. Help me pleace, has serious problem. Have asked and searched around without result, is a bit desperat. So I hope someone can help me.
Have an s13 with RB25DET Generation 2, with:
Eagle rods
CP piston
Tomei poncams
80mm throttle body
aftermarket intake
ported Garret GT3540r .82 ar
Split Fire Ignition coils
Link G3 ECU
1.2 mm head gasket
Denso 850cc injectors
Aeromotive A1000 fuel pump
Apexi avcr
52mm wastegate
adjustable cam gears.
Have run it on the dynapack, according to the afr it leen out between 4700-5000, I cant gett higher rpm, but if I keep the pedal to the floor in a few seconds it goes over 5000rpm and hit the barrier at 7500 RPMs with no problem. Nothing is registrated in the link g3, it is the same problem when standing still so when I drive the car.
Any settings that are wrong?
Someone have a map I could try or compare with?
