Pathy06white »
https://forums.nicoclub.com/pathy06white-u95691.html
Fri Jun 06, 2008 1:53 pm
Slickroger, I have a Pioneer aftermarket deck. It appears all 4 of my Factory speakers have been blown, per a Stero Installation shop who put in the original system. He stated that I should not need a Crutchfield harness, rather just some good replacement speakers.
I am preparing to replace all 4 at least the front two first, and see if standard 3 way speakers will work with the AMP output. It appears the original speakers are 2 Ohm. Most aftermarket are at least 4 Ohm. Will that work ok with the amp that is in the wiring path?
Did you ever consider by-passing the amp and just drive the speakers off the aftermarket head unit. If so, where is the amp located on pathfinders.
Are these 5.25 or 6.5 size?
Thanks in advance on your thoughts. Signed, Every thing sounds tinty.
