not just that....but autozone also sells a rubber adapter taht u can hook a 1/8 size pipping with say some fiting 1/4 big. which kinda gauge...autometerslo wrote:I'm guessing that your boost gauge hardware came with 1/8" vinyl tubing?? It's quite simple. You can go out and get windshield washer hose (autozone). They're like 1/4" or something. That 1/8" vinyl tubing will actually squeeze inside the 1/4" rubber hose. I KNOW you can find 1/4" fittings anywhere
I tee'd my bov from my brake booster. My pulasr had a Tee already but had a screw in the extra spot. So i took the screw out and ran a line from the bov there. bov like direct, powerful vaccum sources.mazikowski wrote:Not to thread jack, but would it be a bad idea to have a BOV and boost gauge on the same vac source (just those 2)?
