Beancooker »
https://forums.nicoclub.com/beancooker-u42602.html
Fri Mar 02, 2007 3:55 pm
I also called my local dealership, and a body shop that I know and have used. They both confirm the fact that on a '99 Nissan Maxima the shift knob will unscrew. Turn in a counterclockwise direction. The knob is installed with an epoxy (thread lock) on the threads. In extreme cases, heating the shift lever below the knob has been known to help. However this is not recommended, and Brad from the body shop says he will ruin a shift knob, and replace it with a new one, before he heats it up. He recommends getting an oversized pair of channel locks and really bearing down on it.
In case channel locks are called something different depending on location in the USA, here is a picture.
