I have 191,000 on mine. *shrug*Jesda wrote:Wow, 93k on an original transmission. It was due to fail 15-40k earlier.
[Sometimes I feel like I'm on a Chrysler forum.]
We will see tommorrow. I'm waiting for my friend to pick me up(Q is my only car) Today I will get some fluid. Then I 'll be back tommorrow and fill her up. I only drove it half a mile when it started slipping. Then I had it flatbedded. I know I wont sleep tonightqship96 wrote:with that much debris trapped in the filter,my guess is that the transmission is toast
The slipping you experienced was actually lockup. It's the end result of a long cycle. Your transmission has been starved of fluid flow for a long time. The more it clogged, the more it overheated and the more clutch material shore off, a vicous cycle. Once the fluid became stagnant (today) due to complete blockage, there was no longer any pressure in the system hence the "neutral'. After your 2nd filter clean, it will feel like it's shifting like new providing you didn't do too much damage. Only time will tell.92Q45guy wrote: I only drove it half a mile when it started slipping.
Actually, this is not true as there is always debris floating around in the fluid, even if it can't be seen with the unaided eye. This debris invariably becomes lodged within the screen mesh if not on the surface. Hence, just like brake fluid, power steeering fluid, ATF and differential fluid, there is no way to deteremine if it is "servicable" until it fails as the deterioration in performance is gradual over time. Exactly why the filter has to be replaced with every pan drop, and all those fluids are replaced before they are discernably bad.qship96 wrote:.....as the filter remains servicable until the transmission is so worn as to shed enough material to clog it..
BG Flush first then clean the filter. Unless you plan on doing it twice?92Q45guy wrote:Well today I added the fluid, Lowered the car and went for a spin. Success! The car drives amazing! shifts on fly and is much smoother. I'm so happy! I'm going to drive it for a couple of days and drop the pan again and clean the filter. Then get a BG chemical flush. One other thing I noticed I had about 6 1/2 quarts of fluid in my drain pan. I know I did some degree of damage to the transmission, but it works so I'm happy. Thanks everyone for your help............And dont go by what the service records say!
I've already added a transmission cooler when I did my chain guides . I mounted it between the condenser and the radiator. So it's not seeing hot air after the radiator. As for the owner before memaxnix wrote:And don't confuse a chemical BG Quick Clean (get the correct one for the transmission) flush with a mechanical fluid exchange.
And don't forget to add the the auxiliary ATF cooler, and add an auxiliary ATF filter like the later G50. And use all new parts!
As to the service record, one has to contact the service manager at the performing dealer and inquire as to the precise meaning of the terms - i.e., what is the actual procedure employed and how is it implemented?
Thanks! Dobermans are great family dogs. They have a bad rap from movies, WWII, ETC. This is my second dobie. He also is very sweet and well trained..........I pitty the fool that tries to get into my house or back yard. He's only 1 1/2 years so he's got another 1/2 a year of growing left in him. He has about a 45 word vocabulary right now! And he loves going for rides in the Q!StarPD wrote:92Q45guy,I like your sig photo.I have a 10-1/2 year old black Dobie, my third. Previous two were reds. He is the sweetest, most obedient, and best mannered dog I and friends, relatives and visitors have ever seen. He is fiercely protective of my wife, but defers to me if I'm around when things go bump in the night.
Dobies are irrefutably the smartest and best all-around family dogs there are.
(Sorry for the thread hijack, but I had to compliment you on your choice of freiids)
