HELP! TCS still not working!
Qshipsta
Hey guys,. ok i took all your advice,. and changed the tcs relay,. the one closest to the firewall, under the battery tray,. tcs still not working,. anything else to look for???,. i'e checked fuses,. and i don't really know where to check for loose conectors,...but winter is officially here,. with 3" yesterday,. i am hardly mobile,. i need some help,... thanks guys. Tim
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
You could also try the switch... It could be bad or something....
There are also TCS fuses, i cant remember if they are in the engine compartment or in the passenger compartment....
rover3l
Car: 1998 Q45, 2000Q45 Anniversary, 1965 Rover 3L,
There are 2 or 3 fuses which are both in the engine compartment and the drivers side of the front passenger compartment near the parking brake release.
Have you checked the TCS fluid level under the hood?
Qshipsta
yea,. i've checked the fluids,.. i've check the two fuses under the hood,. and in the panel,. near the brake,... could the switch make both the tcs and slip lights be on all the time?
rover3l
If the TCS switch is off only the TCS light on the dash should be on
rover3l
There is also a self diagnosis feature you can check. You need to have driven the car at above 30mph for 1 minute and then with the engine still running you need to check the number of flashes from the TCS module LED. This is mounted under the rear parcel shelf in the trunk on the far left hand side. To view the red LED it is best to remove the verticle trunk trim panel and then you can see the LED clearly. The LED should flash repeatedly at 0.5 second intervals. At the end of each sequence there is a pause of a few seconds and then it will repeat a certain number of flashes.
Note the number of flashes and post the result and I can then advise you from the list in the service manual what the result means.
There are nineteen different possibilities that is you will either get 1,2,3,4........19 flashes before the pause.
