SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Thu Dec 08, 2011 7:53 pm
It sounds like you might need a trip to the dealer. There have been several updates in computer software that should resolve that. It also sounds like maybe you might be due for some brakes. If the pads are worn they might slip a little when the brakes are only partially applied causing a lurch. If it is damp and rainy you probably have your lights, wipers, and AC running this will cause the default idle and engine load to be about as high as it can possibly be, add that to slightly less friction from worn pads and you could very well lurch a little bit. That is if it is not engine control related I can't really tell from your description.
Good Luck.
