driverdriver »
https://forums.nicoclub.com/driverdriver-u9137.html
Thu Jan 15, 2009 5:11 pm
Test your battery first.
Go to Canadian Tire and pick yourself up a cheap multimeter.
Set it to 12 volts, touch the positive lead to positive on battery and negative to negative with the car off.
If you get 9.6v and above your battery is okay, if you get it at 9.6v and below your battery is no good. Get a new one.
Do your lights dim and go bright at night. If that's the case you need a new alternator.
If you install a new alternator make sure its a Nissan OEM new or remanufactured unit. For whatever reason non OEM alternators don't last on the car.
