NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Wed Sep 21, 2005 3:19 am
The knock sensor will not cause the check engine light and I suspect a lrage part of that repair if for that. The Knock sensor is located in the middle of the engine under the intake manifold, Which requires heavy labor. You should have inquired about how much just the 505 repair would be. The knock sensor will not hamper performance all that much, certainly not enough for you to notice. The idle valve will however have very adverse effects on the engine.
