nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Sat Jan 05, 2008 3:21 pm
-27? Holy crap. You'll be fine on the inside (in fact, you'll have ~67mm more space than stock). However, you'll have to pull the fenders a ton to get those to fit.
If you meant +27, you'll still need to pull the fenders a good bit. Lower than about +35 is never going to fit without messing with the fenders, and on an 8in wide wheel, anything higher than about +40 (stock offset) will rub on the inside (assuming you run a 225 or maybe 235 tire).
