fulltimeclubber »
https://forums.nicoclub.com/fulltimeclubber-u1256.html
Sat Jan 18, 2003 6:54 am
Ive had to replace my hub bearnig assembly on the front passenger side in a parking lot before so its not incredibly difficult but that was in the front not sure if the back is more complicated guessing it is thoough. Even if it was your rotor thats very easy to replace, I doubt its your hub bearing assembly I'd just replace the pads and rotor on that wheel and see what happens, hey if you do the work yourself itd only cost you like 50 instead of 110 like you said for a new hub bearing assembly, my front one cost me 75 at a junk yard cause dealerships around me wanted 150 for the part and they would have had to order it.
