You didn't search from what I see...http://users.adelphia.net/~rescue70/ecu.htmlICdrifting wrote:so the car will start and run fine for about 5 to ten minutes after that its starts running really bad, it lacks power, almost like if it was runing on 3 cylinders and it smells like gas. i pulled these codes out of the ecu i dont know if they are right:23, 34, 45, 51, 12any help is apreaciated
This tells me that your car's wiring is a bootleg. Please go over your wiring because you obviously left a few wires undone which resulted in a few components either malfunction or not reporting to the ecu.ICdrifting wrote:so the car will start and run fine for about 5 to ten minutes after that its starts running really bad, it lacks power, almost like if it was runing on 3 cylinders and it smells like gas. i pulled these codes out of the ecu i dont know if they are right:23, 34, 45, 51, 12any help is apreaciated
