HELP! OIL PUMP FAILURE?
93s13rookie
Car: 93 s13 and 90 q45
When the oil pump goes bas goes it make any noise? I have the whine I can't locate, and I have to go back to work on Monday! Please help.
jamesblonde82
Car: 1992 Nissan 240SX convertible RIP 5/10/07
1993 Nissan 240SX convertible
do you have an auto? did you actually check to see if oil is getting to your cams?
480sx
Car: 1996 Pearl White 240sx
I dont think a failing oil pump would cause a whine, your whine sounds more like Power steering. What you should do is take a long screw driver(or a stethoscope.. hehe...) and put the tip of it on the PS pump, alternator, ac pump ect ect. Put your ear up against the handle of the screw driver and see if you can hear the noise through it. It will be pretty obvious when you find whats causing the whine.
93s13rookie
This problem started about a week ago when I thought my ps pump was low I filled it and drove it home. I disconected teh ps belt and and the noise was still there. Here is the like to my -myspace page where i posted the video. check it out.http://vids.myspace.com/index....ideos
480sx
links broken
EDIT - Oh you just have to log into myspace.. You should get a photo bucket account its much more net friendly.
Edit 2 .. Lol - Theres nothing on the page..
93s13rookie
I emailed it too you.
93s13rookie
it is an automatic. how do i check the oil getting to the cams?
anthony.
While the engine is COMPLETELY cool and engine OFF, take off the oil cap and sticker your finger in and feel around and see if you get oil on your fingers.. at least that's what my dad did when my oil pump went.
jamesblonde82
93s13rookie wrote:it is an automatic. how do i check the oil getting to the cams?
you can check if oil gets to your cams by removing the oil filler cap and running the motor, you should actually see oil coating the cams as they move.
i figured you were an auto transmission. im willing to bet its your torque converter. they can make a noise that sounds like a PS pump whine when going out. check to see if it locks at highway speed, it should, if it doesnt then its defintely your TC.
93s13rookie
is there a history of tc failure in these automatics? quick fix or do it need to be dropped and replaced? guess ya know i didnt drive that fudda mudda to work.
jamesblonde82
93s13rookie wrote:is there a history of tc failure in these automatics? quick fix or do it need to be dropped and replaced? guess ya know i didnt drive that fudda mudda to work.
well i dont know if there's a history of it, but wierd because ive had two verts both TC's went out on both cars. TC's wear out anyway, and if you got a lot of miles on the transmission, i would not doubt it.
here is a link, read it and learn about torque convertors, there's a diagnosis page that could help you figure out if this is the problem for sure. i know it says toyota, but it applies pretty much for all TC's. and like i said b4 when mine went bad they sounded like a power steering pump going bad. but they dont always make that noise.....
93s13rookie
Where is the link?
jamesblonde82
oops my bad, i forgot to paste the link in when i wrote that here it is...
http://www.autoshop101.com/forms/AT02.pdf
93s13rookie
it broke down on me saturday night. i think the converter went on a a permanent hiatus. may need a new transmission or converter. I'm leaning on the tc bause it drove fine for about 10 miles then i just couldnt get any gear, towed it home.gota a transmission 4 sale?
Vegascorbin
Car: 1990 240sx dirt track race car
Time for the typical Auto to 5 Speed Swap
pwrofdrm
Vegascorbin wrote:Time for the typical Auto to 5 Speed Swap
Sounds like the answer to me...much less BS to go wrong in a 5-speed
93s13rookie
well i agree on that. it wont won't even move. now i just need to source all that stuff to make it happen. yall think it'll be easier to do the whole engine and transmission swap instead of just the transmission? think it'll pass the MD emissions sniffer?
