HELP: Oil LIght
DriFt3r
Car: Racing and Drifting
I just recently replaced my oil and about 200 miles after I notice the oil light fading in and out. Like its going to come on but it doesnt. The light dims right before it gets to the brightest point. Also I just installed a Monster TACH, would that of had an effect on the oil light? I know the oil pressure is good because I have an oil pressure gauge and its reading 50 psi when I am driving. What could be wrong?
S14tat
Car: 2007 FX35
1994 Acura NSX
1996 Honda Accord coupe
1995 S14 KA-T *sold*
did you check to see if you even have any oil left in tehre? the light usually comes on when your low on oil.
DriFt3r
yep check that too oil was still full, it was at the top of the line
DriFt3r
oh one more thing, before I flushed out the oil I added ATF and ran the car at idle for 5 minutes to clean up the internals. Would that have of caused anything?
SloS13
yes, I bet thats your problem. You probably knocked loose some big sludge particles and now they are clogging the pickup screen. Time to undo some bolts :(
S14tat
Car: 2007 FX35
1994 Acura NSX
maybe he has a bad oil pressure sensor?
float_6969
Or the wires could be loose on the oil pressure sensor. They put it right below the oil filter and I know that I poured oil on it every time I changed my oil. You might try seeing how much a new oil pressure sensor is and if it's not real expensive, replace it.
SloS13
Im using a GM sensor for my dummy light. (NPT)
S14tat
Car: 2007 FX35
1994 Acura NSX
they're like 15 bucks for one. its not expensive at all. the only problem is you need a big *** socket to take it out, and its in kind of a tight spot.
float_6969
Real men have big sockets.
WDRacing
What year os your car, has the oil been changes on time all the time?? If so I doubt you had any nasty clogged oil get stuck in the pickup. You have oil pressure, and the level is good. I'd check the wiring to the sensor. And as suggested, try the stock sensor for the light.
As a tip, I'd use moto flush instead of ATF.
WD
float_6969
I was told that engine flushes were a bad idea? And what about with a turbocharged motor?
rudeboy
Car: cars
what came of it.i'm having problems also
DriFt3r
Thanks guys its the sensor wire that broke. Must of broke off when I pu the filter on.
