help my drive shaft is too short!!!
silviaracer
i have searched and the ca one i got and my ka one are both 2 short i'm using ka mounts due to them not wanting to come off.
its not an abs car i know they are shorter
but like i said
i'm using ka mountsand it has the 180sx diff
thanks brad
F3600
humm strange.. on my car everything is fitting right with my KA mount.
you can try to take out a litlle bit the part of the driveshaft that goes into the transmission. You can gain maybe 1 this way
silviaracer
would that be safe to do?? should i make some metal spacers or something
help please
81na ZX
Car: 81 280ZX, 69 Lotus Europa
Well taking off some would make it even shorter
Spacers would have to be PERFECTLY balanced, a little bit off at 80MPH would be VERY bad Ask some F-body guys, caus it seems they get out-of-balance driveshafts all the time.
My vote - have someone make a custom shaft for you. Easiest? yes. Best answer? yes. Cheapest? no. Although custom steel ones aren't too bad. If you've got good places nearby, an AL one isn't too bad either - a friend of mine has a custom AL one in his 510 he had made for ~$225.
slownslurious
go to a junkyard and get one for like $25 bucks or something...My drive shaft started life as a stock 89 sohc one, and it worked with my dohc KA, my CA, and now it still works with my s14 ABS vlsd pumpkin...
silviaracer
i mean its a soch drive shaft i dunno whats going on with it. its driving me crazy. any other options
i don't think this will matter but the engine mount bolt on top are not tight and the front of the car is jacked up i don't think it would make a difference but thought i would state it
slownslurious
um.. yeah tighten them down. see if that helps. If its still too long you could swap your rear diff to one with ABS... does it not even reach? I mean the stock one has a decent bit of slack in it.
Shahee1
Car: 1993 240sx w RB20DET
take a look a few one piece shafs in the junyard ... like a z31 or rx7 ...
NeedCAforS13
Car: CA swapped S13 coupe
KA mounts on backwards? this will move the motor forward...
Sean
silviaracer
they should'nt be i could get the mounts off thats why i used them i'll just let it hang out untill i can get it to work and put it on the lift to swap out the mounts
thanks guys
