Help Me Stop Smoking
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
So after doing an oil change...now running 15w50 mobil 1 the car runs amazing.
However after driving if i sit at idle too long it starts to smoke profucely(sp?) if i give it gas long enough it eventually stops......it didnt smoke before the oil change at all.....any idea?
adrianfromthecastle
Car: 1992 Nissan 240sx
jk..
wildacexxx
Car: 2002 Q45 nav sport
wat color smoke is it? it could be your valve guides or u can be having blow-by indicating your piston rings. anyway wat color is the smoke
SR20Essex
Car: 1989 Nissan 240SX, 2007 Infiniti G35 Coupe
Its valve guides, what he is describing is a dead giveaway. Idle for a bit then it smokes when you give it gas.
Did you add any aftermarket additives? Some of those are thin enough to get through the valve guides even if there is nothing wrong with them. I had that problem when I added some stuff like that. It smoked when I would idle for a min then give it gas. It also smoked as soon as I would gas it if I was going down a hill letting the transmission slow the car. Anything that caused negative crankcase pressure, pulling the additive through the valve guides.
keith1k
Car: S13 Vert
Sounds more like valve stem seals.
wildacexxx
keith1k wrote:Sounds more like valve stem seals.
oops thats wat i meant. thanx!!! my ka had that problem. i just left it like that for over a year. that thing held up great for a motor that was not properly maintained (by me)
drifter_for_life06
Car: Daily: '16 WRX
Exocet
any easy solution?
smoke is white
smells real weird
wildacexxx
that smell is coolant. it smells sort of sweet and or like syrup. might have blown your hg. do a compression test
drifter_for_life06
Car: Daily: '16 WRX
Exocet
definately doesnt smell like that....not overheating
aaronsnocker1
Car: 93 240sx
Your car doesn't have to be overheating to have a coolant leak into the cylinders. It sounds like a blown headgasket/ cracked head(worst case). Usually coolant smoke is white. Oil smoke is blueish and gas smoke is black/grey. At least thats what I think I remember being told in college? Anybody back this up?
wildacexxx
your colors are correct. white def means burning coolant. check for coolant in your oil and oild in your coolant
drifter_for_life06
Car: Daily: '16 WRX
Exocet
hrmmmm
time to investigate
aaronsnocker1
Car: 93 240sx
I'm pretty sure that if you have coolant in your oil the oil will turn into a milky looking substance. And if you have oil in your coolant you can open your radiator cap and look at the surface for oil. Try sticking your finger or some other porous matierial (paper towel, shop towel) and check for oil residue. Again this is all based off of memory so somebody back this up?
drifter_for_life06
Car: Daily: '16 WRX
Exocet
so far no coolant in oil
and im waiting for the engine to cool before poppin the cap
wildacexxx
maybe ur turbo seals went. that would be great for u if it did. better then doing a hg
drifter_for_life06
Car: Daily: '16 WRX
Exocet
how would i know if the seals went? She holds boost fine. 7psi like it should be
i probably shouldnt drive it around but seeing as its my only car nowadays i have to
and for the past day or so i havent seen any smoke while sitting in traffic
could some oil have just burnt off or something? would running lean cause white smoke?
PantherRacer
Car: 1992 Nissan Skyline R32 RB20DET Sedan
so the turbo can smoke if the seals are gone? I think either my turbo is bad or it's not connected properly....though...I don't have the d/p and cat on, just the midpipe. heading out to check my oil right now.
edit: reminds me of what happened in the terk. too much oil. smoked profusely.the 180 has a bit more oil than it needs too. guess I'll let it burn off scince it's not too too much
Modified by PantherRacer at 7:28 PM 7/29/2006
drifter_for_life06
Car: Daily: '16 WRX
Exocet
panther finally got a car? back on track
yea itll smoke
but i dont know how much or what color
bump for anyone that can give some input on my posts?
drifter_for_life06
Car: Daily: '16 WRX
Exocet
ive also recently noticed a slight hesitation at full throttle between approx. 2700-3k rpm
Structure240sx
what oil were you running before?
if this is a thinner oil (weight and or synthetic or not) it could be getting passed certain seals. i would think turbo seals.
i always ran 10w-30 penziol. normal ****. thin oil scares me
PantherRacer
well everyone runs 20W 50 over here. I even used it in the tercel and it was fine.but I'm not gonna buy castrol oil. ever.not made 4 high temperatures and once it hits that magic tempplbbbbbth...loses all viscosity.
but like structure said? what grade is in the car now? and there isn't too much right?
aaronsnocker1
Car: 93 240sx
Well if it is turbo seals then that is beyond my realm of knowledge. You should try and post this in the mechanic section?
spider_slayer
Car: S14 240SX
S13 240SX
if he was burning oil it would have a definite hue to it. fluffy white smoke is a good indicator of a head gasket. i'd try a compression test. then maybe try a pressure test on your cooling system, see if you can find any leaks.
didn't you have this problem a few months back and replace your thermo?
safxtacy
my brother had the same problem with his car turned out he ut to much oil in and the car was burning the extra off he just drained all the oil and put in how much he was supposed to
drifter_for_life06
Car: Daily: '16 WRX
Exocet
as far as the problem before....i donno what that was....it stopped smoking that time after i removed the thermo b/c it was over heating...now there is no over heating and all that stuff
as far as what oil was in it before....i donno whatever the shop that did my swap put in...probably 10w30?
right now its got mobil1 15w50
BlkrwdT
Im pretty sure its your turbo seal is goin bad. Ive had 2 turbos in the past that did the same, smoking during idle and as soon as i give it some gas its gone. Sometime , during idle the turbine shaft doesn't spin, givin low idle and not enough exhaust air to move it, therefor its easier for the oil to creep through the bad seals. As we all know theres no rubber seal in turbo to give it a good seal, so being that its a metal seal thing must be spinning for it to be effective. Anyways, pull off the DP and see if the exhuast wheel is black n wet.
A bad valve stem seal will create smoke at start up. Car parked for a while, oil seeps through seals , combustion burns oil , making smoke. If not then its your turbo seal because the exhaust manifold/ turbo needs to be HOT in order to burn off any excess oil.Hopefully that will analyze things down for you..
c-rad
Car: 1991 Nissan 240SX w/CA18DET
BlkrwdT wrote:Im pretty sure its your turbo seal is goin bad. Ive had 2 turbos in the past that did the same, smoking during idle and as soon as i give it some gas its gone. Sometime , during idle the turbine shaft doesn't spin, givin low idle and not enough exhaust air to move it, therefor its easier for the oil to creep through the bad seals. As we all know theres no rubber seal in turbo to give it a good seal, so being that its a metal seal thing must be spinning for it to be effective. Anyways, pull off the DP and see if the exhuast wheel is black n wet.
Yep, I'm having that problem right now. After the car warms up for about 3-4 minutes it will slowly start to smoke. When I start driving, it goes away. That's what I get for putting a crustyass T25 on there.
drifter_for_life06
Car: Daily: '16 WRX
Exocet
i think im gonna go the route of the FPbig28 to solve this...get turbo rebuilt and all new gaskets
drifter_for_life06
Car: Daily: '16 WRX
Exocet
so do you guys think it is indeed the turbo? i dont wanna spend the 800 sending it out if its not the factor
wildacexxx
did u do a compression test and leak down? are u still running without a thermo? if u were overheating with a thermo on it could mean hg. do appropriate test's instead of guessing
