Help Me Stop Smoking
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
no no comp test and leak down....i dont have anything to do it with
wildacexxx
Car: 2002 Q45 nav sport
http://search.ebay.com/search/...gory0=
or go to your local mechanic or shop
DunnJH4
Car: 1990 300ZX TT Chrome intake plenum, BOV's, exhaust, you know Just under 500HP
BlkrwdT wrote:Im pretty sure its your turbo seal is goin bad. ..............Anyways, pull off the DP and see if the exhuast wheel is black n wet.
A bad valve stem seal will create smoke at start up. Car parked for a while, oil seeps through seals , combustion burns oil , making smoke. If not then its your turbo seal because the exhaust manifold/ turbo needs to be HOT in order to burn off any excess oil.Hopefully that will analyze things down for you..
So if it's the turbo seals you think it would overall disappear at higher speeds? I smoke a lil on startup (especially if sitting for awhile). It smokes just a bit at higher revs, but over about 3000 rpm the blue/white smoke seems to come back. Then i find alil oil in the BOVs and plenty in the exhaust and the back of my car! The last owner said it started smoking shortly after using a fuel additive....
itsnever2fast
Car: 1990 S13 HATCH SR20DET REDTOP
15w 50 too thick... meh... use 0w40
jisatsu
i ha
BlkrwdT wrote:Im pretty sure its your turbo seal is goin bad. Ive had 2 turbos in the past that did the same, smoking during idle and as soon as i give it some gas its gone. Sometime , during idle the turbine shaft doesn't spin, givin low idle and not enough exhaust air to move it, therefor its easier for the oil to creep through the bad seals. As we all know theres no rubber seal in turbo to give it a good seal, so being that its a metal seal thing must be spinning for it to be effective. Anyways, pull off the DP and see if the exhuast wheel is black n wet.
when i start in the morning, no smoke at all.... then i start moving, no smoke...however, as soon as i stop/idle, smoke comes out..... and yes, it stops smoking when i give it gas, but starts smoking again as soon as i let go of gas... i'm hoping it's my turbo seal, too. i have to check this stuff tomorrow
