jdeck »
https://forums.nicoclub.com/jdeck-u271518.html
Mon Jan 30, 2017 8:40 am
Let me provide some background for my post
I am trying to help out a neighbor who had some friends swap a motor for him and left him flat. I am hoping to help him figure out what to do with the car. If it's doable and a good idea I may try to get it running for him. Otherwise I would help him sell it or something in between. I am very familiar with working on Japanese cars and well versed with with Honda/Acura, Toyota and Subaru. I have a Subaru Impreza, 2006 WRX, 1998 2.5 RS that I ice race in the winter and a turbo 1992 Integra that I track Spring-Fall. I am not very experienced when working on Nissans, which is why I am here for help. Below is information that I got from my neighbor.
Here are the facts:
- He has a 1991 300zx (no rust, mint interior - very nice car)
- A few years back the timing belt skipped some teeth and trashed the motor
- He enlisted some car acquaintances to help swap a motor. They clearly knew enough and weren't hacks but they were also obviously not experts.
- He has a receipt for a JDM "90-95" VG30DE and paid $895
- After installing the motor, the car acquaintances swapped out the injector wiring for PHASE II plugs to match the new motor, they also installed the timing kit from Z1
- When attempting to start the car, the negative battery terminal arced and melted
- The car was towed back to his house and not touched since (I think 2-3 years)
- I inspected the negative terminal wire and it almost seemed like it wasn't connected to anything and they tried to start the car so it arced at weak point in the wire. I have never seen anything like it before.
Noted but not confirmed:
- He said he remembers the guys say that it could be a 1998 motor
- He said that he remembers the guys encouraging him to simply have a mechanic finish the car and that it was probably a simple electrical issue
- I truly could not figure out why they stopped working on the car from speaking with him. I thought maybe they felt that their input matched the pay and troubleshooting would put them in way over their heads. The car was also towed back to his home which was 45min travel time for these weekend warriors. However, this is all confusing to me since they had some kind of knowledge to swap the injector plugs and also install the timing kit. Isn't the best part getting a swap running?
Next steps:
- Is there a definitive way to figure out which motor this is? If it's a 96+ then obviously I would advise him to sell the car. I am aware that the lack of VVT and presence of OBDII would not make that a variable option.
- Thoughts on the arcing/melting of the ground terminal (common with these cars?)
Thanks in advance
