Postby
PEZi »
https://forums.nicoclub.com/pezi-u122065.htmlWed Jan 25, 2012 1:02 am
Might be hard to find. While Chevy wheels do fit the truck, the actual stock wheels off of Chevy trucks rarely, if ever, get put on these things. I know I've never seen it!
Postby
PEZi »
https://forums.nicoclub.com/pezi-u122065.htmlWed Jan 25, 2012 11:22 am
I'm curious to see how they look! The only reason we usually mention that the Chevy wheels fit is because you can go just about anywhere to grab some American Racing or similar wheels that are listed as being for Chevy fitment.
Postby
PEZi »
https://forums.nicoclub.com/pezi-u122065.htmlWed Jan 25, 2012 5:17 pm
The tires would be best suited as anywhere from a 225 to a 245 width with a 45 ish sidewall. They will most likely rub a little when the steering is fully turned in the front, but nothing too crazy. It's just almost impossible to not rub with that drop.
Postby
Smyrna720 »
https://forums.nicoclub.com/smyrna720-u195559.htmlWed Feb 29, 2012 7:21 am
I'm not going to touch a grinder to my wheels. Evar. They do not fit without grinding, so this is what I did.
As a side note, I measured the wheels and they're actually 16x7, so the tire size I'm going to be running is 225/60R16's. And it's going to be awesome.
