BruceJ30 »
https://forums.nicoclub.com/brucej30-u79724.html
Fri May 30, 2008 5:39 am
Just recently, my injector went out on the J.And yes, i know for a fact its an injector, ECU code readfor it, so while the car was running, i took all power off to theinjector that i thought was the one not working, andi was correct. It's injector #2, and when i unplugged power fromit, the idle never changed. So i thought maybe the injectorwas clogged or has had it's life.
I took a look at all the wiring on top of the engine that goes tothe injectors, moved them around, and cleaned the terminals, but it was still running rough, so i think its the wiring by the fire wallgoing into the ECU.
But this morning, it was working fine. It was humid and dew was on the grass and cars,so I'm guessing the wire to that injector has corroded orsomething, and the water is completing the circuit.
Anyone have any ideas that would help me when i further look at it?Thanks
