RUSSO35OZ wrote:I HAVE A 03 350Z I HAVE BORLA HEADERS CAT DELETES Y PIPE WITH CATBACK AIR INTAKE PLENIUM SPACER AND LOWER COLECTOR WHAT WOULD BE MY NEXT STEP HELP IF YOU CAN
If you have the money there is plenty you could look into. Most would say F/I but what about doing the rear end, changing the final drive for a better hook up - put more power to the ground, look into good suspension, maybe build the heads or go to Cosworth and check out the built heads and built block. I heard they built a 400+hp n/a VQ35 (cosworth). There is many many routes you can take and things you can go. It all depends on you, and your interests/plans for the car. Fill us in more and maybe we could help - more.
