???????????help gauge cluster problems???????????????
idriftnsj
Car: 90s13
i put new face overlays in my 90 ka24e 240 and i unplugged the cluster when i got done nothing worked none of my guages worked no temp,spedo,or fuel.a couple days later i was cleaning out my car and on the passenger side i seen 3 wires hangin from under my dash green,yellow n purple with female ends on them comin from the ecu to the middile of my dash anyhelp ?????????????????????????????
TDS
Car: 2008 G35
Are you referring to the needles that do not work? Does the the gauge cluster light up at least? Where did you get the face overlays from? We need more details...
idriftnsj
Car: 90s13
the needles dont work the lights come on sometimes and the overlays get power from the fuse box .i put in new fuses and the needles still dont work even the clock dosen't work .but when i was cleaning out the pasenger side of my ca i found three wires 2gether that were unplugged coming from under the dash green yellow purple with female ends on them but i could not tell where on the drivers side they were going 2 but the came from the ecu harness i wil post a pic 2morrow
WWJD
take out your cluster and look back there to see if there are any open spots.
did you take off the needles to put on the over lays? If so, you jacked up you cluster
idriftnsj
Car: 90s13
i think i messed up the connections in the back because my other cluster wont work either ima go cut some off a car in the junk yard and then c what happens
WWJD
Or befor you go and cut and splice wires take a test light to them to be sure
DALAZ_68
Car: 90' 240sx CA18det
Pictures speak louder than words
