elecfus »
https://forums.nicoclub.com/elecfus-u268885.html
Mon Oct 17, 2016 5:25 pm
even though the head bolts are "reusable", they can deform so it's a good idea to replace them as well and you might as well since they need to come out to be resurfaced. as far as replacing parts goes, i guess its just a matter of how much you value your time and if it's worth avoiding another plenum and head pull to throw money at it.
once the heads are off, you can take a straight edge to the block surfaces and shine a torch at the other side, if any light comes through the edge, it needs resurfacing. try it from a bunch of different axis, diagnonally, lengthways, all around the block. on a daily driver 4 banger i dont care about I can get away with just sanding any eccentricities flat but this is bad and nobody should do this.
