my car is not charging. just redo the whole car wiring due to new ecu.
can check how to rewire?
the main bolt to +12V charing.alternator body GNDsocket on the alternator = w/r 10amp fuse to 12Vsocket on the alternator = w/grn =?? charge lamp with 12v??
i try to wire once with the above connection and i see 15V!!! and not sure the alternator is damage now a not.
just the 2 wire on the alternator that i do not know how to wire.
someone please help. need the charging to continue to do my car tunning for new ECU.
thank you very much.
RegardsDerrick
