Ok I did search a lot before I posted this..
With a picture of my car I think you will be able to understand what I'm not understanding..
Here we go..
My car was working and starting fine until the starter went to out.
I installed the new one and the car still didn't started...
Searching for the starter relay while my friend was inside the car turning the key I was hearing the clicks coming from the relay box on the
Driver side when my friend turn the key so I changed some relays around the
driver side... turned and it started 3 times just fine.. I thought the work was done..
A hour later didn't started again and I can't find the starter relay and I don't know where the inhibitor relay is located..
So my question is:
Can anyone who have an 93 vert check for me what colors are the wires that connect to starter relay so I can try to track them down.. or any other info like where they are coming from..
and where is the inhibitor relay?
thats how my car look .. no blue starter relay there
that blue starter relay laying there i got it in the junkyard
This plug is not connected to anything and fits on the small side of the relay... i dont know where it's supposed to be the wires coming out of it are: brown with a white line / black
These two fit the larger plug on the starter relay but they are already in use one is from the 5 speed conversion the other the alternator. you can see the colors there good one plug have
