Help dieing of raw gas fumes
240hatchsx
Car: 93 s13 hatch
Hey everyone I've had my hatch now for a year now and today was the first day I actually filled my an entire tank up with some 93 octane gas with gas being some what reasonable ( gotta love bday gas gift cards ) and right after I left the gas station I had to shut off the ac and drive with the windows down which is not cool in 90 degree south FL heat. I was wondering what would cause my car to smell like I dumpped 5 gals worth of fuel in my back seat
youngun21a
Car: 240sx 1993 Automatic
Check your tank,lift the mat if it's leaking u might have to remove the cover and see if there is a leak on the high or low pressure hose...
Buy My App Need Money For Parts.
http://itunes.apple.com/us/app/allsocia ... ?mt=8&ls=1
240hatchsx
Car: 93 s13 hatch
Well checked where the fuel pump is under the mat in the back of the hatch and I found no fluid there but I was upgrading to suspension tech front and rear sway bars today and noticed that there was some wet areas underneath the car but couldnt get the time to check everything bc I have a date tonight luckily I can always borrow the growen ups car !!! :slap:
nifares240
Car: 1993 240sx Black-Project Car, 1993 240sx Red-SOLD, 1994 Sentra, 2004 Nissan Sentra SE-R SPEC V-Daily, 1999 Toyota Camry
check the in/return line hoses in the engine bay. those tend to tear if you have a bad motor mount
check the clamps on gas line that runs to the filter.
check if you leaky injector which could cause raw gas smell
might have a bad fuel pump O ring if you didn't replace it when doing the fuel pump
