DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Thu Aug 27, 2015 9:20 pm
Welcome!
Generally the best path is to fault-check all components in a code-related issue, but in your case it's fairly clear that you also have some "old style" injector issues possibly playing into your problem. The old style are prone to electrolysis which ruins them, as well as issues with the crappy connectors as well as possibly a crispy harness...all common '90 issues.
Gas coming out the exhaust plus other fluids really only can happen from an injector(s) failing open due to one or more of the above, and the temp sensor could be reading correctly but reading a known fault reading, hence the code...bottom line is your fuel system needs a thorough checkup and maintenance either from a Z shop, or yourself with the troubleshooting area of the OSM found in the "everything you need to know about the Z32" sticky on the top of our page.
Good Luck, and post up any further info you get!
