BruceJ30 wrote:I thought i was getting fuel...We disconnected the line coming from the fuel filterand gas was pouring out and didn't stop until we connected it again...
But we don't hear one thing when listening for the pump.We put a screw driver up to the gas tank and while someoneturned ignition to on, we listened and heard nothing.
You would hear a faint noise if it was working.
On a warm day fuel will pour out even with the ignition OFF and the fuel pump is very quiet (especially after too many 60s/70s rock concerts and sprint car races).
From pages EF & EC 183 and 184 of the 1993 manual:
Hard to Start or Impossible to Start When Engine is Cold
1) check battery and starter - you've been crankin'
2) check fuel pressure - probably OK
3) The check IACV-Air and IACV-AAC valve via the fully depressed accelerator when starting test - you FAILED?
4) Check injectors - probably OK
5) Check spark - probably OK
6) Check plugs - Now new? What's their gap?
7) Check ECM harness connectors
8) Check ECM power supply and ground circuit
9) Try known good ECM, but probably not mine.
