Help! Both front LCA bushings are bad. Di i have any options?
Nissan 350z / Nissan 370z general community discussion forum
redsx13
Car: 93 240sx 03 350z
Ok, like to post says,my car devoloped a strange vibration in the front end, so i checked it out, and it turns out that both my front lower controm arm bushings are bad. weird thing is, the car only has 42,000 miles on it and has never been in an accident.
I looked around but i couldn't find any bushings. please don't tell me i have to replace the lower control arms!!!
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
they are likely a dealer only itme on such a new car, I am supprised to hear this, unless they are subject to fluids or constant washing they should last for 10 years or better i'd think
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
Aren't you the same guy that had all the suspension issues during cornering? (i'm lazy i don't feel like looking it up).
Regardless, in this case, maybe you want to replace the control arms if they wore out that quickly...
redsx13
rmezz13 wrote:Aren't you the same guy that had all the suspension issues during cornering? (i'm lazy i don't feel like looking it up).
yes!!!, im surprised you remembered. I finally found the problem. When i have the time i may be able to get some pics, but both rubber bushings are pretty torn up. I dont know how this could happen.
Replacing the lower controm arms seems like such a waste, since the arms are perfectly fine.
AZ350Z
Car: 2003 350Z Black
I literally go thru an LCA every 90 days. I drift and DD my car, but they do suck. No aftermarket arms either. Tried delran bushings and it was a disaster.
$186 ea. thru Nissan. 10 minute swap.
evildky
06 Nissan 350Z GT
so whats failing? need better a arms? or better tc rods? (does the Z32 use a lower "A" or a aingle pivot lower arm with a t/c/ locating rod?)
BusyBadger
Car: '92 Nissan 240SX
'05 Nissan 350Z
'13 Nissan Juke
Now *that* is some serious steering angle!
Seriously though, that's almost as painful to look at as the Joe Theisman knee video.
I'm surprised Pfeiffer or some of the suspension geeks over at SPL haven't crafted something yet. All B'Ver has for the 350 is for the rear and SPL just has the Upper A Arm.
redsx13
AZ350Z wrote:I literally go thru an LCA every 90 days. I drift and DD my car, but they do suck. No aftermarket arms either. Tried delran bushings and it was a disaster.
yep, thats what i thought. just needed to find someone else that drives theit car like i do.
thankyou!!!!
redsx13
or maybe a little harder.....................lol
redsx13
I have a nissan extended warrenty, do you think they would cover these if i swapped back my stock struts/shocks and springs?
if so, do you think it would be worth it?????
Return to “350z / 370z Discussion”
