RED_DET wrote:Welcome to Nico!
Over the years of owning my sentra, I have learned it does NOT like platinum plugs. The standard NGK BKR5E/6E plug works just fine. You need to check to make sure you have spark and fuel to each cylinder. Start with cylinder 1 and remove the plug, attach the spark plug wire and lie it on the valve cover. Start the car and make sure that plug is putting off a spark. If so, reinstall the plug and repeat steps for the next 3 plugs. If you determine that you have spark to each cylinder, now you must check to see if the fuel injectors are firing. Start the car, undo the harness for the first injector, if that cylinder is firing properly the engine should stumble and run worse, if so plug the harness back in and repeat steps for the other 3 injectors. If you pull the harness off and you receive no change in the way the motor runs, which should be worse, then you have found your culprit.
Report back with your findings and we will go from there.
