SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Sat Jan 03, 2009 3:59 pm
I have been participating in the board for about as long as I have been a Nico member. This is a very diverse board and no matter what your personal tastes I see more interaction and willingness to help out as compared to other boards here. I have learned from lurking here that owning a Classic Infiniti can in deed be done on a practical budget, and can be a fun project. Not many people know the J, I have always liked the Modern for the Day styling of the early to mid 90s J30 line.Parts are another story as an employee of an Infiniti dealer and I know how to find my own parts I would take this car over something newer with a payment and no challenges, what fun is that???
I wanted to share my J story with the other members here.
Recently I had the good fortune to come into a J that was discarded by it's previous owner. This car is a true mechanics special, won't pass emissions and no one knows exactly why. The car seems like it was a money pit for some unlucky guy. I am now looking at getting about a grand of parts and a weekends worth of free work to get this car up to the condition to where I would be comfortable having my wife take to work, and pass Va's tough emissions laws.
I spent several hours testing and disassembling and doing more testing outside in the 20* sunshine on a Friday trying to figure out why cylinders 1 and 3 were hydrolocking, and shooting gas 5' from the passenger side fender. Pulling the plugs out confirmed my suspicions of injector failure. All of the plugs on Bank 1 (passenger side) were soaked in fuel. I hooked up a noide light to verify injector pulse (to see if it was an injector sticking or a ground signal failure). I found cyl #1 was grounded all the time(noide light on steady with battery power even with the key out of the ignition), this confirmed the fatal diagnosis of an Engine Control Module. I resolved this issue and found the reason the #3 cyl had a broken injector cap, once I pulled the injector out (I spent a good 45 minutes getting the injector cap out (w/o taking the plenum off) why not pull the injector to allow for further testing) I found that the lower seal was ripped, which was causing the hydrolock, I replaced the $12 seal (yeah that's the price with a discount, wtf) and it fired right up. Then proceeded to leak antifreeze from the water pump. That's where I left it at 5:30 on Friday. I have a few details to work out before actually taking ownership of this diamond in the rough, so hopefully next week it will actually be mine, I'm just pretty excited. Ultimately I want to build something that is as if not more reliable than a newer car I could get for the same price. I want to return this car to as close to what a J would be if they were on sale now. I have no desire to make a race car, add horsepower, I want a clean classic that runs like it did when it was new. That's not too much to ask for I think. My list of improvements includes;
-Timing belt, water pump (leaking), tensioners (noisy), seals (while I'm in there might as well). All of this needs to be done immediately, because I have a leak.
- All filters, and every fluid will be returned to factory, and I am thinking of running ester oil (150K+ miles). The OE fluids are not cheap, but I want to do this the correct way and I will just have to accept the cost as the price of doing business and the only way to respect the J, I'm hoping it will return the favor.
-Either replace or change the color of every possible light on the inside of the car. I cannot stand burned out interior lights. More than that I hate the color green (reminds me of an ancient Honda) I'm either thinking the blue (02+ Q45 interior lights) or white (no little condom over the bulb). I also really hate the simple black gauge face so I want to either add the white (as some of the members here have had luck with) if I can make the indicators red. I also plan on adding new interior light bulbs in the vanity lights. I'm thinking of going with the hyper white looking ones (Lexus IS license plate lights). - Replace every possible bushing I can find in the parts system, I am most likely going to do it the old school (using a press), to save some cash.
-O2 sensors, like all parts they have a serviceable life and in the not so distant past these were replaced at ~100K intervals and I am looking to get the most consistent performance from this car so I am going to do my best to replace everything that can effect engine operation and factory performance, while restoring a classic luxury car on a budget. I cannot say that I will be going totally factory on all these components, I know the MAF is almost $600, and I am not paying that. I plan to find out who makes the parts I need and buying them direct.
-HIDs- more likely than not the first and only "Mod" I plan on doing, I think halogen lights are seriously outdated. I have been stock piling old headlights from newer models and I am going to see what will work either putting the projector (adjustable height ) but the lenses are pricey and I want to keep it stock looking so I might try to see how they work without having to bake the only set of lenses I have. I have seen a few members here do something similar using the readily available kits, I'm going to make mine using stuff I already have so well see how that goes.
-Undercoating- This car has very little to no rust (must have been a Southern car at some point in its life) and I plan on keeping it that way. I have been looking into getting a spray on undercoating setup to DIMyself and save yet more cash while also making the car quieter. I would like to go with the Eastwood under coat sealing, I would like to remove the rear subframe and spray everything under the car to prevent future cancer and cost.
-Fix the Dash- Although 90% of the interior is in great shape there is a very annoying crack on top of the combination meter and theh defroster vents are popping up. I think the damage may be able to be repaired but I don't know if it will look right. The vents should be easy but the crack I have a feeling will never blend correctly. Da*m lack of using Armorall and solar abuse.
-Working Audio-Some other Nissan radio that will work with the factory cd changer (if that still works), there is no power button and I have yet to invest the time into assesing the current audio situation, but it's not looking promising. Again I want to keep it pretty stock looking, with the simple interface.
-Window viewability-I really do not want to tint the windows (or at least more than 10-15%). I'm not looking to make a "cruiser" that is going to set off red flags with the numerous authorities in this area that are eager to stop and question me. When I was younger I had a large red Bonneville that was red with 5% tint and I was stopped several times to question me, I'm grown now and I am not looking to give them a reason to slow me down.
-Audio-I think adding a double DIN nav enabled audio unit is out of the question (I really do not want a break in). I am thinking of mounting something like this mounted in the headliner or drivers sunshade depending on space allowances and ease of view ability. I am looking to comply with the industry wide standard of <30 degrees of eye movement needed for full visability without mounting something in plain site.
-Wheels???- I really don't want to make something VIP or custom looking I would like to get rid of the factory BBS wheels (I know these are highly sought after) but I want to get something like the 07 G35 Journey wheels, nothing fancy just simple and stock off something else. I don't know if that will ever come to fruition though. Unless I can find someone to repair the clear coat in at a price the wife may agree too. (Ahh the joys of adulthood, lol)
-Speakers- I like my music clear and loud (when I drive alone) so I think speakers from a 14 y/o car will not last me long. Boston Acoustic FTW.
-Interior carpet- The rear parcel shelf has faded from black to a very interesting blue, while I really like the color blue it doesn't really match so I think I will need to re-upholster the parcel shelf and any other faded fabrics. This is not a huge job but given the age the integrity of sun beaten parts is hit or miss.
-Leather Treatment- The leather in most of these old cars is stiff and faily rigid (in comparison to the new cars I drive all the time) I am going to look into a treatment to either repair this or chemically convert the seat surfaces to be more comfortable. I have always wanted to do upholstery work like that.
-LED tails???- I really like the look of the FX/G tail lights I want to add this feature in a factory looking manner to my car. If they come apart in a practacle fashion I want to add LED circuits to illuminate the rear. I am not going for a ricey look, I am thinking more like a Caddy center illumination design (lights up but you cannot see the lights), I want to accentuate the Infiniti design in a tasteful manner.
Well now that I read over this I realize that it's an awful lot for an introduction, I have to admit I am excited I have not had my own car for a few years (no need, given my location, and the saving are well worth the ego shot that was required). If any of you have made it through this long rant and dream session I applaud you.
If you guys have any other suggestions or need photos of anything or you can give me some advise (always gladly welcomed) I would great appreciate being able to help a community I feel like I have just joined. I will post pics once she's clean and web worthy.
Thanks for reading Steve
