heating and air hissing noise
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
mikeym41240
When i start up my car and turn my air on i hear a weird sound coming from the motor,like a moving grinding sound or something.Just when the air is turned on.Is this the compressor and should it sound like that.The car heats up fine.Also i get this hissing noise inside my car,coming from around the glove compartment or a little lower.It eventually stops after about 5 or 10 minutes.Its a little annoying.What is causing these problems and how could i fix it?
mikeym41240
anyone that could help me i appreciate it.
alonsorules8.1
Car: 2008 Nissan Versa SL
2010 Nissan Versa S
the air conditioning compressor is noisy with the versa and makes a grinding noise it is normal according to Nissan just turn it off and back on and the noise goes away and or will be greatly reduced. If you are still under warranty have your Nissan techs check it out. as for the hissing noise I don't know what cold be causing that condition.
wygal
Mikeym - did you ever discover what the hissing sound was? I have the same issue. Thanks!
Return to “Versa Technical Discussions”
