DjLiquid »
https://forums.nicoclub.com/djliquid-u26615.html
Thu Jul 07, 2005 5:54 am
Ok. So I finally got my engine dropped into the car and I was adding antifreeze into it when I noticed something. I had a small leak on the back of the block. Upon closer inspection, the hose that was leaking was the one coming off the metal pipe going to the oil cooler. It's a bit of a fuss to change (had to remove the axle and the oil filter+cooler) but so far it's ok. While I was under there I noticed that a nipple coming off the metal pipe wasn't attached to anything so I thought I would ask where it goes to.
Description of the heater hose:
There's a metal pipe that comes out of the block thats about 3" long. It's just knocked in there and held in place. Off that metal piece is a 90 degree plastic hose. This plastic hose couples another metal pipe thats about 1' long and about 1.5" in diameter. Off this long metal hose comes a few nipples. Starting from the part closest to the 90 plastic coupler you have a nipple that goes to the oil cooler. After that there's another nipple (mine isnt being used and thus the reason why im writing this). Then as you follow the metal pipe you will find 2 nipples somewhat close together. These go to your heater (the 2 nipples sticking out of the firewall). After that there are a few miscellanious nipples that go to the turbo and then it finally ends with the end of the metal pipe that connects to a large plastic hose that goes to the lower part of the radiator.
Now as I described, the second nipple that comes off the metal pipe on the back, I was going to block it off but if it's vital for something, I wanted to know what it went to so I won't be restricing anything of antifreeze
Thanks =D
