I had problems just solved them though, replaced switch (visual inspection of solder points usually plenty) replaced relay (blue, first relay above fuse box under dash driver side) replaced motor, connected good harness (with zero splices)and checked all wires (single ground under dash, the switch and 2 wire to motor) replaced resistor (left of motor) and yes they were all shot, lmao! but still nothing... turned out the fuse box was not making proper contact with fuse (#7 fuse, 15a), cleaned contacts and re-gaped them (they were too far open) and now I have heat
so even on a seemingly flawless harness there are always hidden little things, like a gap to large in the fuse connector
