Heater/AC fan blows fuse 95 Q45t
Tman Sr.
Car: 1995 Q45t
Whenever the fan goes to high the fuse blows after a few minutes of operation. To avoid this I manualy set the fan speed to the 3rd position which avoids the fuse problem. However while in this position it seems to "hunt" speed up and slow down on its own. I know that on auto it is supposed to speed up and slow down as the temp in the car reaches set point however it seems to speed up and slowdown repeatedly in quick succession. Should I be looking at the fan itself or is there a resistor that might be faulty?Thanks for any help you can provide.
Q45tech
Owner failure to replace or rehabilitate HVAC fan when the motor becomes worn and slows down --------drawing excess current blowing fuse.
Replace HVAC motor and clean AC core BEFORE it burns out the fan speed controller!
Tman Sr.
Car: 1995 Q45t
Thanks so much, are there instructions on removal of the AC core on here? I looked but didn't see anything.Thanks again.
goody90q45
Car: 1992 Infiniti Q45 (sold)
In the FSM in the Body section there's instructions for removing the glove box. After that, remove the metal brace and the blower fan is staring you in the face.
Chances are your fan blades are full of dried dirt and its too much weight for the blower motor to turn it without burning a fuse. When my fan control amp burned up my blower blades were caked thick in dirt.
Remove the blower motor assembly, then remove the blade assembly from the motor and clean it off real good. Chances are you've stressed your fan control amplifier which sits in a rectangular cutout adjacent to the fan motor. It may need to be replaced also ($65 new). Just in case, check the operation of the blower before reinstalling the glove box.
While you've got the fan control amplifier out clean the crud off the condenser face. Air will flow much better. Most cars have a cabin filter for this but not the Q45.
I have a nice fan motor (but not the fan control amp) for sale if you need one. Good luck.
Tman Sr.
Car: 1995 Q45t
Thanks for the detailed info goody I appreciate the help. I'll give it a go this weekend.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
goody94q45 wrote: Most cars have a cabin filter for this but not the Q45.
That is not the G50 Q45. All others do have cabin filters.
goody90q45
maxnix wrote:That is not the G50 Q45. All others do have cabin filters.
I stand corrected. The 90-96, G50, Q45 does not have a cabin filter. From Brian's statement later model Q45's do have a cabin filter.
Tman Sr.
Car: 1995 Q45t
Hey Goody, I took out my motor and fan wheel was really quite clean, bushing however are worn and brushes and armature are very warn out. Looks like I will need a new motor shortly. How much do you want for your motor? Is it new?
Q45tech
Used motors are iffy as they are the same age no newer than 1996 made in 1995 [13.5 years old].
Q451990
But they are a fairly rare failure item... and if they haven't been exposed to undue moisture causing corrosion, their failure should be more related to revolutions (directly related to mileage) than age...
Heath
