Heated Seats?
PINODY
For those of you who have Heated Seats, is it Just the seat BOTTOM, or does the Lower lumbar area of the seat BACK also Heat up?
takos
Car: 2008 Wicked Black Rogue SL AWD
Both bottom and the lower lumbar area heat up
PINODY
takos wrote:Both bottom and the lower lumbar area heat up
I hope this is the case ... then the RO would have a slight advantage over the CRV.
barbecuesauce99;279300 wrote:The 2008 CRV manual saysBoth front seats are equipped with seat heaters. The passenger seat only has heaters in the seat bottom because of the side airbag cutoff system.
takos
Edit:---Yes, both the driver and passenger seat heat up in the lower back as well.
Modified by takos at 5:46 PM 11/8/2007
Return to “Rogue Forum”
