I agree, get ceramic coated. Do not heat wrap at all, period. You should never resort to that. You can get a "clip on" heat shield custom welded that would work better for your purposes; particularly something that redirects the heat downward when your car is in motion. Its not exactly an engineering challenge to make that kind of shield, and will save you more in the end.c-rad wrote:Get it ceramic coated if anything.
slownslurious wrote:but that would only make it look prettier.. I mean the name says it all, aesthic coatings...I'd think if you were going to the time and expense you want that special coating, whats it called, swain or whatever?
Hehe, I was wondering if anyone would comment on that. I dissasembled the turbo and had the exhaust housing coated the same way. I have a pic of the whole thing assembled somewhere.biosehnsucht wrote:interesting, didn't know the stock mani was set up for divided inlet (never took my turbos off the mani's)
niec packing peanut, almost looks like it got coated too
Is stock manifold better than tubular 4-1's ?float_6969 wrote:The stock mani is actually a good setup. It isn't a 4-1 like the ssautocrap mani's are.
In the fact that it is basically crack proof and it uses a divder so that you don't have the exhaust pulses from other runners sucking back into another port, yes, it is a good manifold. But it isn't equal length and has limited flow.Vetal wrote:Is Is stock manifold better than tubular 4-1's ?
