http://www.q45.org/darlington.htmlJakw wrote:Wouldn't the darlington make the fan blow all the time though? Such is not the case. I can make it blow high, or not at all. 1-3 = not at all. Automatic mode will put 1-4 on, depending on cabin temperature, but the fan still won't blow until level 4.
I'll check into that dignostic business, thanks.
Alright dudes, I'll give that a shot first. Thanks.I'll go ahead and assume that it's in the same location in the J as it is in the Q then...yes?yodawill2000 wrote:Ive replace a few Darlington's in the past and that's the exact symptom
All or nothing.
I don't know, but Joe (or someone on his team) will be glad to tell you if the part #'s are the same across multiple models. Talking to them is one of the biggest benefits of calling.Jakw wrote:Alright, thanks man.
Is the blower motor the same in any other Nissan/Infiniti? I want to grab one of those too, but I don't know of any J30s in salvage yards around here.
So... behind the glove box looks sort of a lot different in the J than the pictures I've seen of Qs. I guess...what am I missing? I have the box off and that's as far as I've gotten.yodawill2000 wrote:Ive replace a few Darlington's in the past and that's the exact symptom
All or nothing.
Just want to confirm, it fixed your problem?Jakw wrote:Alright, so here's what I learned.
-You just have to remove the passenger side kick panel, nothing else.-There is no metal rectangle. It's white plastic.-The plug that connects to the foot-area light on the kick panel connects to the Darlington assembly also.-The two bolts that hold it into place are 8mm.-This is one of those somewhat cramped jobs that will piss you off if it's cold outside because you'll keep dropping things.
